Rizz
Hello.
I have never been used to the programs of the ansys line (I have always found them very ostic), however having to perform a fluid dynamic anlysis I need fluent.
I designed an object with solidworks and I successfully imported it into gambit.
from gambit I cannot save it so that fluent can read it; What do I do?
gambit saves me only in .dps format (along with other 4 files scattered); When I try to charge it, I get the following errors:
thanks in advance.
Code:
reading "| utility fe2ram -tgambit -d3 c:\users\user\desktop\prova.dbs"...
error: bad syntax. usage:
utility fe2ram dimension read_format zoning write_format [inputfile [outputfile]]
utility fe2ram dimension read_format zoning write_format [inputfile [outputfile]♪
size: [-d2 | -d3 | -surface]
building...
grid,
error: null domain pointer
error object: ()
