solidworks su hdd esterno
  • Thread starter Thread starter Marvel
Marvel
Hi guys, maybe the topic has already been dealt with, but I haven't found anything on the forum. is it possible to install sw, the 2018 version, on an external hdd and have the same functions as if you were working on your pc? I also searched the internet but I didn't find anything.
Thank you!
m
Bye.
I don't know sw 2018. but you can normally install programs in any location.
during installation indicate the external disk and there are no problems.
The only limitation is that there will be a certain slowdown, but maybe you won't even notice. depends on the use you do and the files you load.
about functions, I miss something: as said the physical place where the program resides is influential.
If you mean you can install the program on an external disk and just take that back, I'm sorry, but you can't.
only standalone programs, which install all their files in a single folder, can be moved where you want and used on each pc. All those who make a "normal" installation, even if you indicate a folder or a specific disk, however install a significant amount of files in other locations, typically disk c and user folders. then your external disk program will only work if connected to the pc where you made the installation.
hello francesco, thanks for the answer and the delucidations.
only standalone programs, which install all their files in a single folder, can be moved where you want and used on each pc. All those who make a "normal" installation, even if you indicate a folder or a specific disk, however install a significant amount of files in other locations, typically disk c and user folders. then your external disk program will only work if connected to the pc where you made the installation. ....
It was just what I feared.
I will have to find another way....if there is....:unsure:
Bye!
m
you can install solidworks on external hd provided you install windowsfirst
windows on external hd are years that you can install, etched versions windows enterprise that allow it, there are free sw like wintousb or at low price like todobackup and others,
search windows to go,
are years that install trial versions of various programs on usb even with online activation,solidworks I never installed it on usb
Thanks mistermaster! I move with win first, then. I try to search windows to go.
Bye!
m
Staff online
