solidworks: surface cut
  • Thread starter Thread starter PICO
PICO
do you know if there is a way to make a superficial cut on selected faces?
I'll explain.
we imagine having a solid, for simplicity a cube or a parallelepiped.
we imagine drawing a plan or a planar surface that intersects it.
Good.
if I make a cut with surface (passing) they generate 2 bodies distinct from the initial solid.
if I wanted to make a cut that penetrates the body only of 1 cm on each face, that is a line that enters every face of the tot solid, but does not cut it into its inner core, is it possible?? ? ? ?
or I would like to have a reticle of subdivisions on the various faces, but maintaining a single body.
would be great if you could select which faces should receive the cut and which should be left intact... .
thanks to the magician who can answer me.
