son format name as property
MARCOC
good morning to all, do you think there are ways to get the sheet format name as property? ? ?
I ask you another thing, and you can set the classic descition(size 1) sheet which and any default according to the type of format, so that you visualize as from my example a4 a3 a2 etcc?? ?
the sheet size if you want the fishing directly from that set in sw is one of the properties, you can insert it in the cart. see image... do not need to rename the sheet...in any case there should be also the sheet name to be able to insert
I hope I've been helpful
thanks strudel,my was not a property problem,it was to understand if it could set a name to the format and recover that data from where I indicated with the red arrow
thanks cmq for the answer
...he also takes the sheet name... see image is always in the properties of the sheet "sw-name sheet-sheet name" but you have to set it on document not property of the part
you know, the problem and always the same, and the name of the sheet format that I need
thank you anyway
Hello
Excuse the intromission,
If I didn't misunderstand you would want the sheet format text in the feature manager to comply with the sheet format name, then if it is an a3 instead of "sheet 1 format".
I tried to edit the .dwrdot file of my a3 and modified in the "sheet 1" feature manager with a3, then I also saved its sheet format.
I created a table on a3 format and remains in the feature manager.
Isn't that what you wanted?
then for the property just point to the variable as recommended by strudeldemele.
marcoc wants the sheet name to become automatically corresponding to the sheet format.
if insert a folder a4 the sheet name must become a4, if it changes format in a2 the sheet name must be a2.
This is not possible for the simple fact that even if it is connectable to a string, which is not possible because it is simple text, at the time when 2 or more sheets with the same solidworks format could not handle them because the names of the sheets must be unique.
on the net there should be macros fishing from the file properties the values to give to the sheet name.
for the property I would say that the thing is trivial and you see very well in the post#3 that is present (fifth voice after the highlighted one). changing the sheet name the property adjusts accordingly.
jenuary,the problem and just what wrote you massive,thebproblem does not arise on the single sheet,but when you have the multifoil,he instead of used "format sheet" and then the progressive,it would serve me to take a custom name from me and then its progressive to discriminate the various sheets
I understand:
independently solidworks does not do it as it said well massive.
you could do a button that does it by launching a macro, but I don't know if that's what you want.
I would need you to take a custom name from me and then your progressive to discriminate against the various sheets
which you have not written or explained anywhere. indeed you have just specified that the name must take the name of the sheet format and not that it must be a progression of something
