special chain
  • Thread starter Thread starter sps
sps
I am making a project that includes a transmission with a set of knits of a certain size. not being the cinematic between the chain of knits and perfect wheels the two wheels are kept away from a spring.
Moreover, the non-perfect cinematic is also taken into account by small springs that adjust the radius of 'dents' at a time. How do I simulate the bike to see if at least it works? :biggrin:
for the truth after many tests of good setting of the constraints and setting the motor to a wheel I get of the movements:cool: that however they hire to the chain conformations stane, of course because you do not consider well the elastic defs:frown:. I have seen that in the application->motion-> menu a motorcycle analysis environment opens: Apparently you can set the defo. :36_6_6: etc. in practice what would serve me.
Does anyone give me tips on how to use that tool?
I have already seen other similar discussions on the forum but apparently no one talks about this environment
the motion environment allows you to study your transmission system thoroughly. But you would need the full version. once called dynamic motion. But I don't know what happened to this software.
