Fabietto
first, the view you refer to (grassetto) is not the plant, but it is front view.Now a question arises spontaneously, is it necessary that I make the view from above? in the previous design for example, I could have quoted in the view in plant and the one from the right and end there?
Then I'll ask you the question. .
you, with the only front and side view, would be able to put all odds and above all,
would you be able to understand (you) how the particular is done?
