strudeldemele
sw2017: I have many difficulties in the table of complex assemblies and I would like to understand if I am applying all the options to lighten everything:
- light weight / large assemblies;
- all blocked references
- frozen parts;
- minimum image quality and edges
- I followed the site settings: https://www.formame.it/2018/03/20/m...zioni-con-grandi-assiemi-senza-compromessi-1/ to be considered:
- the axieme has a part with guide sketches that modify some functions (eg length and position main profiles of the frames)
- pc.
- cpu: i7 8700 4.2 ghz
- gpu: nvidia framework p2000
- ram 16 gb
- disco ssd samsung pm871b
I hope you know how to help me, I'm making a table mass not very heavy (about 80 components with perfectly geometric shapes and only perforated... 5 mediumly complex sheeting) which is becoming prohibitive, the pc is also blocked for 2/3 minutes
Thank you very much
- frozen parts;
- pc.
- ram 16 gb
Thank you very much
