spessori linee pdf
  • Thread starter Thread starter giotama
giotama
Good morning to all
when I save a dft in pdf I have problems with the thickness of the lines
become all big and often in areas of detail overlap by compromising the legibility of the design?
Is there any remedy I'm missing?
you need to change lines styles by choosing a lower thickness
solid edge by default uses 0.5, which also according to me is a sproposito
I use 0.35 mm as thickness for thick lines and 0.25 mm for the thickness of thin ones.
to preview how the printed design shows you can enable the option "view as printed" in the "view" tab of solid edge options.
the thicknesses indicated are the same that I use but noticed a decided increase in thickness when from the dft step to pdf.
this becomes then "uncomfortable" when you have seen with very small details or when for graphic needs you put in solid edge some line (in my case of annotation arrows) with a thickness increased for example 1
in solid edge display remains sharp and without overlap
in pdf thickness 1 seems to become a 3 so of the drawn arrow remains something incomprehensible. . .
pdf molds on the correct sheet size? back time we had the same problem, then we realized that we "printed" formats a2 a1 and a0 always on a3, and this caused the problem.
but create pdf using the save by name or printing on a virtual printer?
I with the save by name never had problems, especially if you use the size of the individual sheet (every sheet takes the size set)
I tried both ways but it seems to change little. I have the feeling that above the thickness 0.35 the pdf becomes unreadable in the areas with nearby lines even if in solid edge you still have sharpness and absence of overlaps even with greater thicknesses
Please try to see the test files I put herehttps://dl.dropboxusercontent.com/u/5427234/spessori linee pdf.zipthere is both the dft and two pdf one obtained with save and one with print
the sheet is an a4
the sheet is an a4
to me everything seems fine in the pdf you sent.
I also printed them in scale 1:1 and the line thickness is correct.
did you try to activate "view as printed" in solid edge?
to work I keep it disabled, but when I have to retouch the thicknesses and the spacing is important to activate it to realize what you are doing.
You're right! !
I didn't know this display option and I often fell into the trap to think that the problem was conversion to pdf
for example also the dotted fills of section views I saw them change between the dft and pdf
with this active option instead there is full correspondence between dft and pdf
all clear then: no conversion problem but only a display setting I didn't know!
Thank you!
Hello everyone,
I have the same problem with the thicknesses, however I cannot change them.
I activated the display as printed and changed the styles of the drawing views, creating a new style with thicknesses line of 0.25 mm, however even if I attach it to the design view or change it in the options of solid edge on the page "style design view" does not change anything, I have huge lines on the dft file and obviously also on the pdf.linee spesse.webpthanks in advance for possible help.
Hello everyone,
I activated the display as printed and changed the styles of the drawing views, creating a new style with thicknesses line of 0.25 mm, however even if I attach it to the design view or change it in the options of solid edge on the page "style design view" does not change anything, I have huge lines on the dft file and obviously also on the pdf.View attachment 41109thanks in advance for possible help.
from the image I see that you are modifying the line thickness of the "style views", i.e. all lines of service related to the view (e.g. the edge if displayed or if "accorci" a view).
what you want to change is the thickness of the "line stems".
Thank you for your help,
Actually this changes the thickness, however I have to change the individual style of line every time, unless I do it on a template that I will use in the future.
is there no way to create a custom line style setup as in the case of "stili vista design" or "stile quota" and then apply it to other dft designs already made?
other curiosity: what is the use of the line thickness settings on "design view" if you do not see results?
Thank you again!
thank you for your help,
actually this changes the thickness, however i have to change the individual style of line every time, unless i do it on a template that i will use in the future.
thank you again!
all custom styles would be good to create them in your template. if you have multiple needs you can create multiple templates already set (e.g. one for each customer).
you can copy styles from one file to another using the organizer.
the line thicknesses on "style view", as i have already told you, serve to define the thicknesses of the lines of the view (not the lines of what is represented in the view), for example the edge of the view (if shown).
hi.
do you know if you can apply a style thick lines in a simple way to drawings already executed?
