spiral coupling on tree
  • Thread starter Thread starter xxfast
Hello.
I can't define the couplings between the spiral and the attached tree.
Could someone explain the method to make the concentric spiral to the tree? :bekle:
create the spiral axis and concentric ties to the tree.
Right.
I was about to say.
in the part, after which, the sketches are activated in the assembly and the coupling is made.
:finger:
Wrong. . .
Do a "axis" with the "axis" command, not a sketch, but if you need the axis do that.
Wrong. . .
Okay, thank you, Marco, now I've also met another command from reference geometry.
as you see from the attached image I used the axis command.View attachment 22738I take advantage to ask you tips on positioning the propeller at a certain distance on the length of the shaft.
I solved it by inserting a plan as a reference to the point of origin of the propeller.
I also give you advice: intelligently position (and not by chance) the model in space and close the sketches when they are black and that is totally defined.
in case no axis was needed but 3 couplings between existing plans in the parts.
if you further sharpened the ingenuity with a single coupling of coincidence of the axle orifices with enabled the alignment check you would have done everything.
I have to revise the crystal bowl:redface:
having him 2011 and I 2010 was the only tool I could use, but maybe it is not broken, there was little signal dolo. . .
if you further sharpened the ingenuity with a single coupling of coincidence of the axle orifices with enabled the alignment check you would have done everything.[/QUOTE]Thanks, but I prefer to use the axis.
also because I will have to insert other components it seems more clear to me to use the axes.
As for sketches, you're right, I have to define them, but this was just a proof that I'll have to do as a leader.
You stopped or are you still waiting? 2011 is much better than 2010 long ago....
