cikho
I have a small modeling problem (wf4)
Let's say I have a piece like that attached.. I should basically "spray" the colored surface in blue so that you create a conca
(I identified the blue surface for clarity), but the perimeter of the blue surface must remain where it is, without moving.. and sopprattutto I need a "controllerable" way and therefore I can't use the scolpisci because I have to apply this modification on different pieces keeping the depth of the conca constant (3-4mm). .
I tried a lot of roads, but no one seems to go where I'd like to go. .
Do you have any suggestions?
Thank you very much:
