split view, thickness section.
leggera
Hello.
but is there an option to make a split with the thickness of the piece?
creates the section with the net cut.
Are you in part?
How did you do that view?
If you have a plan at that point go to the view tab, view in semisection, select the plan and see the section at that point.
you can also set an offset from the selection plan.
