splore; straight?
  • Thread starter Thread starter piccio__87
piccio__87
hello to all;
Do you have any plans to do an explosive?
I don't know where to go! !
I own inventor 2010!
once you create the ipn file you care about the assieme and proceed with the manual scan.
on each component you want to move do button dx-> "Adjust component position"
the rest is very intuitive.
I suggest you leave the automatic explosion alone because you'll waste more time
thank you pierarg;
It's quite intuitive! ! !
even before reading your advice I checked from me that automatic explosion is a crazy thing. .
is there a way to give a "change to the image" so that all components can be better displayed?
I don't know how to explain it, unfortunately if I don't know how to do it, I don't even know how to give it a precise name...
in the table a curvature of the image, so as to show all the details... .
I'm sorry, but I don't understand.
at most I recommend you to report more areas and explode areas: make a global view of the axieme with holes that indicate areas.
then in separate tables do every single area... .obviously on the design of assemblies for each zone also put the corresponding design code.
or you could try to put in partial transparency the pieces that are not important.
Thank you so much... slowly I'm taking my hand... if I find what I can't explain the writing!
cmq also with the manual you lose a tide of time....especially if you want to show the tracks because depending on where you click it makes you double track
when you are finished moving all the pieces, change the browser display type to correctly set the editing time, group sequences and change viewpoint. becomes all much cooler to save in .avi
hi diegus, I'm making very complex axiom explosions with inventor 2012, would you please explain here passages you described above?
Thank you!
When I'm coming!
the explosion in avi, the quality of the video is very poor, too? Any advice?
