sports part of the assieme
  • Thread starter Thread starter blubossa
blubossa
is it possible to model a part within a set and saving the axieme is saved also the created part?
In practice I find the file of the part and hold it with the part inserted.
The set is, in fact, a set of parts placed in a single file called together.
when saving the various parts are saved inside the same
joint folder, transcribed specific cases.
If at the time of the creation of the part did not ask you a specific name, you can select it from the tree and with the right button of the muose on "open part" and once the part is opened you can save it wherever you want.
on this theme help is the first thing to read.
I noticed that within a set it is no longer possible to create a part, while being available the sketch menu.
in fact it is possible to make an extruded cut but not a semple extrusion. ...
to create a new part in the axieme you must click on the command "new part"; elementary, huh? :wink:.
what you're talking about are commands for the functions applicable on the assemblies.
as they have advised you must read the help, because we are talking about the abc, and without that you do not come out, even with our help; you have to understand the principle of operation of swx, after the commands you already know where to look for them and when you can apply them.
... you must understand the principle of operation of swx, after the commands you already know where to look for them and when you can apply them.
al di la di swx, the problem is concept
together you can do processes that remove material, not that add it!
Wow, it's like pretending that in the workshop they make a piece on a carpentry without drawing it...:eek::confused:
would be convenient after turning or milled a piece and having noticed that it was wrong, being able to add the material to be able to "repair"...:biggrin:
Bye!
p-h
in vs. help was very helpful I have already tested and it is suit ok.
on swx I followed the tutorial about the cardine, and everything went well.
now my question is:
I then create a part directed in the assieme and therefore the exporto it maintains the point of origin relative to the assiemne, I would like to know if it is possible that the part maintains as origin that of the part.
