spostamento layer
gtsolid
I would like to move a drawing from one layer to another but so I know that I lose the colors and styles of the lines originally set.1674572480222.webpDo you have any idea how to keep them?
if you select an entity and you change layer the properties of the entity, if they were forced, remain the same. made the test right now.
explains the process of how to change layers
- select objects to move
- "move to another layer" command
- insert the corresponding layer number and get a flattening of colors/styls
Never used that command.
more simply select the object and change layers via layer management or through properties.
