Flev
Hello everyone, I have doubts about the following problem (a sketch attached to understand geometry)
you must size the figure spring so that the game between the two vertical profiles can vary between 1 and 6 mm. profiles belong to two weight benches of about 100 kg. in practice when mating the counters screw the screws m6x40 (there are 4 in all, arranged according to the vertices of a square) and the spring should ensure the maintenance of the required game.
in the sketch I did not indicate quotas, however at the minimum game corresponds a spring arrow of 9 mm and to the maximum one an arrow of 4 mm. is also given the diameter of the housing (phi in figure) and the free length of the spring l0. What makes me perplexed is the fact of not having a certain load to be able to dimensional the spring.
to ensure the value of the game that forces should consider? or rather, the forces with which the spring reacts for the required arrow values, which other forces should balance? screw shooting? the force of friction of the first detachment of the docks?
thanks in advance and greetings to all
