stages and premises
  • Thread starter Thread starter geodav
geodav
I have the following problem:
local created in the state of fact
in the design phase shifted a delimitation wall of about 40 cm
When I go to create the new place, it tells me that the surface is rounding but I can't see the existing room and I don't even see the new one created. even the label is not added. .
Can anyone help me?
i have the following problem:
local created in the state of fact in the design phase shifted a delimitation wall of about 40 cmwhen i go to create the new place, it tells me that the surface is rounding but i can't see the existing room and i don't even see the new one created. even the label is not added. .
can anyone help me?
thank you.
hi.
do you mean you demolished the existing wall and built the new wall, or moved graphically (translated)?
I mean demolished and rebuilt moved by 40 cm.
the problem only happens to me on a level, on the upper floor for example
by clicking the local creates it right
You should see the file...
... maybe the walls do not intersect the quota of the "level" measurement....
