stampa in pdf
  • Thread starter Thread starter abelli12
abelli12
good morning to all users, I immediately come to the problem: when molding a dwg (acad2004) in pdf, at the rescue
to the file name I always see that the following model text is added (1)
I tried different settings but unfortunately nothing changes.
If someone had the same defect, how did they solve it?
what set should you perform to save with the only file name?
model (1) is the default name that generates the pdf engine, when saving you should be able to delete "model (1)" and name the file as desired.
