standard
  • Thread starter Thread starter dalmott
dalmott
I have a catpart made by another company where they set their standards (thick lines, colors sup, etc);
Now I have to work on this file, and I want to be able to delete these standards, you know how I should be doing?
Thank you very much
Manuel
select the geometric groups and the interested solids, then:
Selected dx/object key/restore properties
or:
menu/modification/property/graphic and act on colors, lines/curves, points etc. modifying them as you want.
some things I had restored them with the restore, the change of properties is not heard (for security I cleaned everything also with the cadua); the problem is with creating new entities, these always take the old settings.
Thank you very much
I can't recreate the same conditions as yours, in the tests that I make the properties are always restored integrally, and if I create a new body or a geometric group, take the default settings.
in the case of copy and paste there is the possibility to inherit the colors of the reference feature
to change the parameters:
menu\instruments\options\infrastructure\part infrastructure\document part\colore on import management
try to change inheritance
then when selecting the part, in color ownership/management (you can select the option)
even if I don't think you're gonna do anything in your case.
Let me know.
ps when changing properties always select "automatic" instead of option.
I tried to change the various settings, but it doesn't seem to change,
I also created a new environment, independent from my classic settings,
I attach a file that comes from the offender.
As evidence, when creating big lines are always thick.
Thank you very much
Manuel
try using the "guided procedure for graphic properties" (the icon in high orange ball and magic wand)
select the original body and then what you created, and check the values that appear in the window (fallo for colors, lines, points etc.)
as you see in my case the first body has been modified as thickness, while the second added keeps the default.
It can be that the file they gave you has "locks" in the graphics properties.
Let me know.
Hola,
pardon for the delay, it is true, it seems to have blocked the graphic properties, and does not depend on the standards; I re-subscribe the masters of the file, and see if they can tell me something.
