meccanicamg
the forces on straight or helical teeth are calculated with the three classic formulas:hello to all, this morning I looked at the wheels of helical teeth, I think I understood most things, I would like to ask you, as yesterday, if I understood these things correctly. another curiosity concerns the forces acting on the teeth in the grip: on the khk manual I have seen that there are no special formulas for the determination of such forces (axial, radial, tangential), for gears with displacement of the profile, from that I deduce that you should use the formulas for normal gears, even if they contain the primitive diameter and the angle of reference pressure and not the operating ones.... is this my doubt....
in reference to gear images:
as usual the forces are calculated on the application point belonging to the primitive diameter (which is the circumference where the rooms are as wide as the teeth) even if it is not the real one of ingraining. Moreover the pressure angle on the primitive diameter is 20° while on the primitive diameter of operation does not have the same value. it is assumed that behavior is almost identical and therefore the classic primitive is used.
