startup startup
  • Thread starter Thread starter mascla
mascla
I should make a table of measures as enclosed 800x400 closed
extendable 1600x400 the extension system consists in sliding lontudinally towards left the brown color plan of 400 mm then the underlying plan of green color has to follow the percose of the groove then placed in order to speculate on the parts in grey (guidadx and sx) I have to be able to extract it and flank on the brown plane without going to interfer with the purple part' I wish to simulate the thing if
thanks to those who will give me support
claudio
claudio
Annex to the question
claudio
Hello claudio
Sorry I'm late, but I missed your post.
first explain to me how you claimed to run the plans as pins and groove/guide have no correspondence.
then if you want the parts not to interfere with some geometric/dimensional changes you are obliged to do it; or you turn off the boards one by the other (maybe even doing the higher sides) or however pins and guide you have to resize them/change them.
I tried a possible solution (can be different, see what you need) changing something, see if it can suit you as a basis on which to work:View attachment TAVOLO.zipView attachment MOVIE.zipanimation is not the maximum (it is not my strong) but should make the idea.
I left the guides "free". if you need the "dents" of arrest in that area you will have to make them wider, because in the files that you placed the pins had no chance to pass (other than the impossibility of realization).
Marco:smile:
Thank you very much for your help
from a first summary view of the footage I think can be good
If I change the channel inclination as you think I can go, Monday morning I will take a look at you have files now I am with Mac I can't
thanks again if you have a contact skype I place it in pvt
Thanks again
Hello claudio
