States exam 2014 / 2015
vinz1996
Good morning guys maybe I was wrong with the blog's discusion is that I apologize.
I wanted to ask you a question.
I am 18 years old is attending a technical technical mechanical indirection, this year I have to give maturity, I should choose on what to argue my tesina.
I decided to ask you before asking the teachers of my school only to present myself in front of them with clear ideas.
I would like to ask you if you give me some inspiration, some argument that I could rely on to do a unique and inimitable job.
thank you in advance and apologize so much if I have stretched too long.
Bye. You can do anything.
For example, I would avoid those throws even if teachers usually know nothing outside their usual things.
Recently there are many who make the hydraulic pantograph lift, so you will find both on the forum and on different material network.
if you want to do something interdisciplinary, design, mechanical technology etc. you could follow the wave of those who made a parallel lathe from hobbistic (and we also have it on the forum), or another machine tool, a press bending machine, a stamping mold (we have on the forum a very long post with so much info). you could make some machine of some processing plant like for rolling mills or cross-cutting of sheet or longitudinal cuts.
If you're smart and have some material and some idea you can make great designs. sr you know how to use the 3d models and do animations, with the fem you can do effort analysis etc. all this is captivating and high-level.
you could also study a carburetor of wasp or hi....Recover everything from a demolitor and demolition, rilevi, models, studies, modifici etc.
are beautiful ideas thank you so much I wanted to tell you that I also have a diagnosis station in my school, do you have any suggestions?
I would personally have thought to simulate a problem to my car and then through the diagnosis station to fix it, or together with a prof we had persuaded to work on the car as it enters the curve or has when it is subjected to some sudden change of direction on the forces that rise in balancing the weight of the machine so as not to throw it off or overturn.... what do you think??? What do you think you have? ? ?
I would do something recommended by mechanicalmg because the material is readily available.
I wouldn't put myself on the dynamics of the vehicle because I see it very hostical.
hardly the high school from mechanical expert enough form to handle such high-level issues.
Do you know how to make differential equations of the second order? Can you analyze vibrations, damping, forcing, managing 10x10 matrixes and beyond, do integral and derived to multiple variables?
If the answer is yes, then go on studying the behaviour of the vehicle.
you guys have been very clear thank you so much I will do as you told me thank you so much and apologize the trouble!!!! :finger:
