salvatore87
Hello everyone, I have to dimension an air condenser, with tubes for a steam system, predetermined geometry, which exchanges the power of 25,6mw. the condensation temperature is 39°c while the air input and output temperature is 20°c and 29°c. the main problem is that, with these data, the air flow to be sent on the tube beam is 3ton/s unthinkable for fans. So I thought to break the system in 3 or 4 modules, so as to reduce the power for each module, and have smaller flow rates per module. the arrangement adopted would be that in parallel. What do you think?
p.s I cannot use water capacitors! !
