salvatore87
Hello everyone are struggling with the sizing of a steam generator, for a concentration plant with 10mw peak parabolic mirrors. the thermovector fluid is diathermic oil, while the input temperature in steam turbine is 400°c. based on this data I determined the temperature of the oil input and output from the generator, respectively of 415c and 330c, and the water input of 53 c. I calculated the power to trade between the two fluids
25,88mw. at this point the only missing data to calculate the necessary surface is the overall coefficient of heat exchange. to do this I separated the transformations in the steam generator in three stages:
1) Liquid heating up to the p=30 bar(inlet pressure in turbine)
2)evaporization t=235c
3)superheater
for each of these phases I calculated the global heat exchange coefficient, hypothesized the only presence of the convection.
the determined values were as follows: 53.9w/m^2 k ;58.6 w/m^2 58.9w/m^2 I would like to know if these values are plausible thanks!
3)superheater
