steel pipes ø 1000 mm
  • Thread starter Thread starter Chris_BRB
Chris_BRB
Good morning.
Can someone tell me a supplier where I can find commercial tubes of 900/1000 mm diameters?
thank you, I also found the second and third link but the first and fourth are made much better, thank you :d
of what material is spoken, of which thicknesses?
How much do you need?
In some cases they build from sheet metal, if the quantities are not exaggerated.
I am already hearing a supplier among those that indicated massive, however 2 rings and material will adapt to what is on the market considering the size
two other solutions could be: a plasma cut sheet or forged. . .
but I don't know what thickness you're talking about and what material. . .
