C12carbon
Hello.
I am designing a threaded shaft that allows, through the manual drive of a flyer, the closure of a shutter of a valve used for liquid transport. the dimensions of the shaft are: diameter 18 mm and height 200 mm approximately, and I chose a carbon steel c40. Now I would like to ask you, what are the commercial dimensions of the semi-finished steel rounds, from which, through processing to the lathe, can I get my tree and waste less material possible? a company advised me to start from a 30 mm diameter round and length 6 m, but is it possible that to obtain a diameter of 18 mm I have to remove more than 1/3? there are smaller dimensions and especially how much they cost per kg or per meter?
Thank you for your answers
cordial greetings
C
cordial greetings
C
