sticker on circular surface
  • Thread starter Thread starter Antodima77
Antodima77
Good morning I should draw a sticker to attach to circular surface.the adhesive should have a graduated scale.
you have suggestions thank you in advance
hi as antodima77 says the decal is very simple, create the surface you need, after which you do a new sketch and insert the image and then select the face you want to lean on.
