niki
Hi, maybe you've already talked about it but with the search I couldn't solve. ..however, I have the drw of an asm, in its prt were made holes that I would like to quote with the famous hole table. then I choose a c sys in the prt, then asks me a c sys in the 'root assembly' and I go to choose one but every time tells me that the orientation is wrong, I have already tried with different orientations. Can someone tell me what the problem is?
(if I could do drw on the prt I would have already solved)
Thank you!
Thank you!
