Stop frame generator element
  • Thread starter Thread starter rf.infissi@libero.it
I created a frame with frame generators with ilogic I want to disable elements but not turn them off.
It doesn't make me wrong with the rule but it doesn't suppress them.
I thought because they were at a lower level but from the frame assembly level you can not generate a level of detail so I can not suppress with the rule.
Please help me I'm getting crazy
Suppose you have together1 with inside skeleton and frame0001
create together1 the level of detail "mioldd" (or the name you want)
open frame0001 in a new shutter (so not a simple double click from together1) and create "mioldd" also there (I have tried with equal and also different names, does not change: as long as they are customized praise)
now being a ldd both in frame0001 and in combination1, and activating them (it is not enough that there are, or at least so it seemed) the rule works.
do not ask me why, I tried some other combination but either did not suppress or error: so goes.
Bye!
You are a genius who works everything and suppresses the element to my command.:biggrin:
But now I would have another question to ask you, if I suppress an element through ilogic, the distinct components are updated of the missing quntita, of course after saving and updating, but if we suppress a part or element of the frame manually the distinct components are not updated even if saved or agglomerated (or tried in all possible ways).
What do you think depends on?
I got my ass, nothing more!
Yes, I also followed the other discussion, but frankly I have no idea. when I did the tests for this thing anyway I noticed that the deleted part via ilogic was displayed at the table as if it was a reference (but not selectable via ballpoint); those manually suppressed completely absent. now that about that suppressed via ilogic is not present in separate (as you said), those manually suppressed there are...
it seems to me that ilogic not only sopprima but also snacks the component as "referral"
However, I can no longer make the element removed from the distinct... Boh!
