stop manipulate on clash
  • Thread starter Thread starter mespo
mespo
Hello everyone does not work me the detector of interference(stop manipulate on clash) of one component compared to another. this once activated
should avoid movements with interference, but it doesn't work for me.
I suppose I didn't set up some parameters in the tools, but I can't find it.
If someone can help me.
thanks early
if you move the particular by hooking the compass (or compass) to the particular that movements (the compass must become green), before moving the particular according to the direction of the compass, you must press the maiusc button.
hiring
keeps putting a component inside the other you see image.
I do not understand with the interference detector(stop manipulate on clash) activated
This shouldn't happen.
but you should block the movement of the first component to the contact of the other.
try using this second method:
activate interrupt option on interference (1)
call the manipulation command (0)
choose a movement direction of the part es.x (2)
ties with respect (3)
try to move the object by selecting it with the left mouse button (hold the pressed button and move to the other object)
if you work this probably wrong something in using the other.
Thank you
Now it works me, and I forgot to activate the option with respect to constraints,(3)
without activating it does not work.
