bear69
good morning, as already written in the presentation message work recently in office design with solidworks 2012 that is new both for me and for my colleagues, before you worked only in 2d with autocad.
My problem is the following, I should make two separate archives, one for the 3d and one for the tables. I started creating parts and assembling in a folder and then created all the relevant tables in the same folder. Having to make a separate archive I moved the tables to another folder, at the time of the opening of the drawings I came out a message that did not find the components and on the table instead of the various views I appeared rectangles with its diagonals. I know that by doing this I have removed every relationship between boards and 3d is that the separate search has been defined by the project leaders in the advanced phase. how should I structure the project and then realize the type of storage required?
Thank you in advance.. .
