strange message
  • Thread starter Thread starter LuiVerde
LuiVerde
\\ impossible to solve the segment pmdcsegment to which reference is made in the file c:\users\luigi\documents\inventor\testina_mag\perno_rotella_vulkolan.ipt. ♪
This is the message that appears to me by opening a set, the ipt file that is recalled does not give me any error, and I do not understand that it means "pmdcsegment" what can be? Did the same thing happen to any of you?
use inv 2011suite sp1.
(important note I can still work, msg appears only at the opening of the assemblies containing it)
Hello and thank you
the first (and unique) thing that comes to mind is that it concerns some projected geometry and/or some adaptive sketch.
Did you check that you didn't have notices in the browser bar?
did you try to copy the file and replace what you have in the set?
I've never had strange messages, but some weird behaviors, kind of didn't migrate, I solved them simply using the copy, maybe rename it....
I solved the coupling again, (perhaps it was a conflict between a parallel spline connection and a key, however now it does not appear + ) thanks to the straights
