strange points on screen
jim78b
I can't understand why they comapionate like unremovable dots on screen, I regen move, I used groups that are those? if mold are not seen..open the full screen image to see them thanks
will be point entities.
to verify it use the pdmode command and set the value 32.
if around the point a circle appears are point entities and ouoi eliminate them or ignore them
which then would be in the drawing points, which one says: e va bhe if there you point them on the screen ie gives 'na pass cor strazzo and nu little de alcohol and nun sees them more.
Now that I am on the pc of the house I ask you:
but instead of doing huge screnshots that just lack to see the walls of the room, why don't you take a circumstantial screenshot? What is difficult to paste the image into paint and cut out what interests you to see?
Have you tried to select those points? Have you tried to make a quick selection and see if the items appear in points? Why didn't you attach the file instead of making us sneak on the countless possibilities that may have created those points, if they were points?
selected but did not select. ..then I tried to erase all the design and remained. I have no layers blocked .. then I recharged the dwg and disappeared .they were like the final points of the quotas ... but impossible to delete .
