strange simulation
  • Thread starter Thread starter sps
sps
I've been learning to use at inventor professional 2010.
But today that I did my first structural simulation I was a little surprised: following the tutorials I was very satisfied with the simulation setting procedure, even through parameterization, but there are two things that do not go:
-the graphic representation of stresses and/or deformations does not follow any criteria: if I move the model to right of the screen this becomes all red, if it is located left becomes all blue, placing it more or less in the center assumes a colorful color from blue to red, from left to right, that has no meaning...:eek:
- if I try to indicate the maximum and minimum points, the frames are displayed, whose writings are like geared images, such as unidentified pixels of a photo. the same thing happens if I zoom in or close....or if I interrupt other points...:eek:
I would like to know if it is a question of mismade preliminary setting, a somewhat strange normality of inventor:confused:, or is it the first time you feel all this?
I say that all other commands, so far used on modeling worked properly as indicated in the guide.
Someone answer me? :3513:
For example, a compression bar is displayed:
color depends exclusively on the position of the model in the screen! !
I don't think it's a video card problem.
the mesh works, the other commands all work, because compatibility with video card only makes whims for simulation? :confused:
:frown:
