enrico1979
Bye-bye.
It happens to me something quite strange or:
if launch patran and let the work dyrectory remain the default (i.e. the temp folder) solution (and then .t16) files are created.
if instead I create a workbook in which I go to copy the launch icon of patran to make sure that the software sins and works in the newly created folder (right click on the patran icon, I choose properties and then I cover the path related to the new work directory in the row relative to "da"), then in launching the analysis nothing happens and when I go to monitor the existing solution, I get a work message from error or
Of course, everything is related to the configuration utility setting and being able to make sure that the various jobs are not all collected in the default software temp folder (only way when I know to rejuvenate to get solutions) obviously guarantees a certain order and cleaning otherwise not easily obtainable.
I wonder if something like that happened to someone and managed to solve the problem raised.
thanks in advance and good work to all
