stratigraphy walls
  • Thread starter Thread starter Eerene
Eerene
Hi, I'm new in this forum and would like to ask for advice on the use of wall stratigraphies on revit 2018. having created a wall with four layers (1-external coating, 2-insulation, 3-structure, 4-intonac) I need to display only the structural elements (state3) in the structural plants and all the layer in the architectural plants. is it possible to manage the display in this sense? I can't find in the display settings a way to display only part of the wall layers and at this point I don't know if it is possible. Do I need to create multiple coon walls different functions? one for every layer I need and at that point manage the wall elements for the display I need. I thank everyone who will respond to me since I have always found this forum useful even though I am only enrolled today.
I thank you for the answer but I don't understand how to handle the display. My problem is like that dealt with in this question https://www.cad3d.it/forum1/threads/materiale-strutturale.33949/ but once I divide the wall into the various independent stratigraphies how do I manage visualization? Should I replace visibility to each layer individually? I thank you so much, as a beginner I cannot find the solution
for revit ver. 2015
is as you say for substitution of vg to each layer;
or you should draw non-structural layers such as architectural (as you said in the first post) and with a unique vg setting make the lines of such layers invisible.
p.s. I do not know if in the following versions of 2015 we proceed in another way.
in the vg command settings I can decide to "think" the walls elements, so all the layer. how do I manage the individual stratigraphies as they belong to the same type of element? Maybe I don't know how it works. . .[Mi sembra strano che in un software come revit che ti permette di disegnare agevolmente un muro con all'interno tutte le stratigrafie poi non ti permetta di gestirne la visualizzazione perchè appartenenti allo stesso elemento. Dovrei quindi disegnare più elementi muro e assegnare ad ognuno una funzione (=materiale) diversa. Mi sembra una soluzione complessa rispetto alla semplicità con cui si può disegnare su revit.]Thank you for the answers you have given me that I have been very helpful!
you are not working for "materials", but for "discipline" (structural/architectonic). in the properties are already present the display selectors for discipline, which you can further customize in the vg
Keep in mind that setting the vg of a view, you can save and transfer it (set) to other views
I still don't understand. from the vg settings I can choose whether to display the wall element, so either I see it all or I don't see it at all.
if I change discipline of a view from the properties I have two cases:
-muro designed by the architecture card displayed with active architecture discipline, not displayed with active structural discipline;
-muro designed by the structure card displayed with active architecture discipline, displayed with active structural displine. (structural structure visible in both cases!)
if I divide the stratigraphy with command manage stratigraphy the wall in question remains visible to me regardless of which discipline I activate.
I'm getting smart, but I probably miss a few steps to understand the matter.
