structural analysis proe/solid edge
  • Thread starter Thread starter sbriso
sbriso
Hello, everyone.
I would need this information:
1 to carry out the various analyses with proes (baricent system, moment of inertia etc.) contained in the function analysis => model => mass property is sufficient to set the material and its relative density or should I also fill other parameters contained in other functions? What are they? :smile:
2 converting a file to stp from solid edge (both together and part) then open it with proes, materials and various parameters (density etc.) set in solid edge remain in memory after the reopening of the step with proes or do I have to reset them again? and if I have to reset them again it is possible to do so without prejudice to the final structural analysis of the system?
thank you in advance for the valuable help.
As for your first question I would say that if you impose well the material and the units of measurement you should be in place, for the 2 I don't know how to answer, cmq in doubt you should do some tests, hello.
