MichMik
Good evening to all
I am a new user of the forum, I opened this discussion because I have a problem with the analysis of a structural element in patran and I don't know how to solve it, I hope you can and want to help me.
in practice I have to analyze a structure that has the form of a rectangled rectangled parallelepiped subject to a torque moment at one end and totally stuck at the other end; therefore it is a beam with rectangular hollow section with thin walls. I shaped it with quad4 elements with shell properties. the problem arises when I have to apply the torque moment, I tried to create a knot at the center of the rectangle and to connect it with all those of the final section of the beam with rbe2 elements and then I applied the torque moment to the central node, but I read somewhere that the rbe2 elements introduce an additional rigidity in the section and maybe this is the reason why, when I analyze the results, the war section instead I also thought of using rbe3 elements, but I don't know exactly how to get with them a simulation of the structure's behavior as close to reality as possible.
Thank you for your availability.
