structural element in welding
graziano-g
Bye.
I recently started using sw 2015 premium sp5, I need to build a frame with a square tube 15x15x1.5, section that however under sections - standard iso / type - square tube / size was not present, there were only 4 sections the smallest of which 20x20.
after asking a question to the right person I found an old discussion with a link to a beautiful library that for convenience found below: https://www.cad3d.it/forum1/attachment.php?attachmentid=17855&d=1290672000
I insert a library for "standard" profiles in fe.
had been created and posted taaanto time ago by the user gabriele swx. is well done and very useful:View attachment 17855simply add them to the weldment profiles folder (or from options point the system directly to the new folder) and will be available in the "welding module" as structural members.
Marco:smile:
I was able to use the section I needed as in the library.
to complete this path in which to insert the content of the .zip file
c:\program files\solidworks corp\solidworks\lang\italian\weldment profiles\iso
But now there's something to fix, when I insert the profile, this message appears to me:capture-20170519-234809.webpIs there any pious soul who has time and desire to do what is recommended in the message?
Hello, thank you.
There's nothing to do. open the profiles and save them with your version. the profiles are simple sketches, of graphic materials, is this to which photoworks refers, does not use it. probably is a standard message for the version jump. in 2014 no longer exists photoworks replaced by photoview360
a small advice on profiles:
I don't know how they're made, but be careful that they don't contain variables. this could create problems if you use different measurements of the same profile as the first profile that is inserted adds the variable to the part and all the profiles that you will insert later if they contain the variable will assume the initial value. practical example: insert a heb 160 that has a radius of 15 managed by a variable r; then insert a heb 400 that has a radius of 30 always managed by the variable r; in this case it commands the first value then you will find a heb 400 with radius 15. little thing would seem, but not if you have to be incarcerated, dozens of reinforcements that then do not get stuck.
However, for completeness of information, find the libraries also in the bread taskImmagine.webp
very kind, thank you.
to access the user library is indispensable internet connection?
However, those you have already downloaded are valid. you just have to save them with your version to delete that message and possibly integral the properties if you use the separate cut
.. and to save them with my version there is a recommended procedure?
back to the previous message: also for solidworks content it is necessary to connect to the internet to you must set a path on the pc?
open the file, to speed up the thing I recommend drag&drop that is to drag the file to explore resources to the solid screen, and save.
it is necessary to be connected.
save the files where you saved the others or create a new folder. the path you find it in the system options>positions of the file> profiles of the welds
