structural member states
  • Thread starter Thread starter Tantocattivo
Tantocattivo
I have frames made with the structural members, and to make visible also of the "internal" parts in the table I use the display states. the problem is that even if I actually do not see solids, when I go to quota or bubble select the same hidden parts. I tried to temporarily change the style of view, but nothing changes. Do you have any suggestions?
diaactive selection of transparency, selection in lnv reticle mode and selection in rln mode
I had searched on the internet and you had responded in the past, but I tried and nothing changes. on display/selection I have unchecked "active selection through transparency" and unchecked allow selection in lnv and rln mode". I tried various random combinations but nothing changes! I also tried to rebuild, change sheet
question:
Why use display states to see hidden parts?
second question:
How are the views set?
third question/council:
Have you tried to use filters?
-the frame created with the structural members is a part, but in reality the carpenter makes two different parts and then joins them using other profiles. with visualization states, I try to create listed views that recreate the workflow. I could make sections (as I did others), but diagonal pieces obstruct the view. If I had been together, maybe I would have created configurations by suspending the parts.
-The views are set on high quality, and also in other parameters around I put high details.
- with filters I wouldn't get big results.
the strange thing is that the options you suggested before me, had to be the perfect ones to solve the problem!!! ♪
