Morin
Bar? What's the point?Let's start.
bar 10 mm x 10 mm x 1000 mm
type of analysis : thermal static
thermal conductivity : 60.5 w/m/°c
specific heat (by following analysis) : 434 joule/kg/°c
boundary conditions:
See Annex
mesh: body sizing 5mm
I am studying the heat produced in braking on a disk. list my data:
- maximum diameter disc 1200 mm and minimum 650 mm
- disc thickness 50 mm
- c45 disc material reclaimed
- the circular crown on which it strips the ferodo has diameter max 1196 mm and minimum 708 mm
(clearly it is necessary to consider this crown on both sides of the disc)
- quantity of heat entering on each circular crown 1870500 w
- braking time 0.52 sec
- initial disk temperature 30 °c
- convective coefficient considered h=5 w/(m^2 k)
expected result: tempered disk about 400 °c
result obtained with fem: tempered disk about 1200 °c
is therefore evident the discordance obtained!
