MARCOC
hello to all, I was trying to use the ambient of solidworks animation, and I came across the command "contact between solid bodies", then I made a blind with 2 pieces to try to understand how it works, I applied a linear motor to one side, the other fixed seal, I activated the contact between bodies, the anointing animation, but the moving part does not feel the contact of the other body,
Does anyone know if it is possible to do this or the contact command works otherwise? ? ?
Thank you very much
Thank you very much
