style line table
  • Thread starter Thread starter Ghirarduzzi.G
Ghirarduzzi.G
Bye.
I have my problem.
I have to create a table to insert in the drawing cart. the problem is that I must insert voices in double English and Chinese language. to correctly display Chinese ideograms I have to choose a particular font that is however unreadable for European characters. Unfortunately you can't set different fonts for a single cell so I can't format part of the text with a font and part of the text with the font I need for ideograms.
Therefore I would like to "enge" the system by creating separate cells by pretending that they are one by changing the style of the cell boundary line to make it invisible. what you can do habitually with excel for example.
is it possible to do it in the tables of creo?
Thank you in advance.
Thanks, guys.
Unfortunately as always happens when I finished writing the message I saw the command icon.
In the meantime, I have another problem.
Now the carts I created bring the voices back to Chinese. at clay level everything works perfectly.
However, when I export to pdf, the file that is generated reports all entries in English, but instead there are no Chinese entries.
I press that when I open other files that come to me from the cina, after uploading a special file of adobe reader for the use of ideograms, I open them correctly.
Is there any operation I have to do to make sure that export from creo to pdf takes place correctly even for ideograms?
test with option convert characters to strokes
Thanks worked.
in the sense that the pdf that is created is not the maximum because the letters are transformed into lines and curves from what I understood so they grow a little (because they follow the formatting of the drawing) and it seems all a little blurred and bold.
But then when I try to print the pdf the result is perfect. So that's fine.
Thanks again.
