subscription advantage pack per autocad mechanical 2010
  • Thread starter Thread starter GiGa
GiGa
available for download (for users with active subscription) the "subscription advantage pack for autocad mechanical 2010 ".
hide and isolate objects — you can activate and deactivate objects regardless of layers, to save time in their detection and thus be able to quickly show or hide objects according to need.Select similar objects — you can select objects with similar properties, such as layer or line type, or blocks and xrif with the same name. create by selection — you can create a new object for a design by copying the type and properties of another selected object.put hold on the second floor — it is possible to optimize the work with the restraints thanks to the possibility to select them and put them easily in the second floor in the drawing.
they will not be added numerous, but they seem quite comfortable.. .
