subsection
  • Thread starter Thread starter teoros
teoros
Hey, guys.
I have to make a partial section of a tree to show a hole made on one of its ends. in the 3d I created the section of the tree but in the table I can not find the command that makes me partial this section, avoiding in this way to dissect the whole tree.
you can use an offset section, creating the sketch that delimits its extension.
But if you put an image of what you need, we'd understand better.
another system is that of the local section.... depends on what you want to do.
and I think the solution I need is the local section. I'm trying to put it in practice tomorrow morning.
Thanks a lot, guys.
Good evening
Hey, guys.
Yeah, I think the local section is what you need.
the only thing, is that when you go to set the depth of the partial section for the cut, you have to select it in the view in the plant and not on the same view where you want the section, otherwise he cuts it for the whole depth.
in the two images I highlighted the passages: in the first, select the reference plan corresponding to the half-piece in the view in the plant, and in the second, select a edge in the terminal part of the tree on which you want to create the split. then click on "apply" and you should get a result similar to the second image.
I tried, but I can't get what I want.
I made a simple planing section on the 3d and in the 2d I excluded the tree as I do not want it all dissected.
I want to only dissect the part highlighted in yellow.
other question: but is it possible to show the hidden lines only of a particular? In this case I can only show the hidden lines of the tree just to show the hole for the screw?
to me I am drawing of this cradle seems to have already seen him around...maybe in briance....boh
