GiGa
Having to make a refractory filling (powered as a single volume, not brick) I have to subtract various elements of the frame that create the shape of the refractory itself, in addition to the drowned zanchettes. everything is simple if it comes in the part of the refractory the axieme of the frame in which it is contained. It is more complicated to avoid a level of assembly by subtracting the encumbrance directly into the axieme that contains the refractory. an easy example to make understand what I would like to do: in a set I have a cube (the refractory) and two rounds (for example two tubes) that cross the cube. how to do the subtraction of the rounds from the cube, obviously keeping the adactivity in case of moving the rounds themselves? I'm losing myself in a cabbage or can't you just do it?
