support for correct sheet metal development
I appreciate the help of both but at carpentry level reality is different. First of all there is the discourse of the discharges folds...................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
Yes, I understand the needs, but that inventor can make you the collected waste and other automatic adjustments, I see it hard.
I don't know if other modelers do.
Is there any specific program you think it does? because then having to collect everything and change in nesting is a mess...
But how many developments do you have?
I make the optimization changes for cutting, I do them on the development dxf created by inventor, if you have few developments, it is not a great job
and but it's just the drains and grooves that cause me errors in the program that I asked for advice.
So I'm the one who didn't understand your problem! In your answer, don't you talk about waste and groove?
I can't get the changes that I can't get directly from the folded side I go to create them on the flat side and get all the fittings and downloads I want.
for example normally I use the angle joint with overlay and drip discharge set to zero in the folded model then the round discharges "connected" I add them on the plane model.
in my inventor 2016 it does not let me make changes to the flat part (developed)!
I have the professional and can do it, obviously in the basic version there is no function activated :eek:
