Luca pax
Hello.
I tell you the problem in summary: I should lay a surface, like a drapop, on another surface.
This rhino function handles it but in a basic way, i.e. I can make a selection window that then projects by supporting the points on my target surface. the problem is that the generated surface passes beyond my target surface and is unmanageable.
I would like to be able to choose the surface to "support" as if it was a fabric of a certain size, on my target surface, which is not flat, and it is not only one, but a series of surfaces....type... a hull.
Is there a plugin for this?
