MB78
another small step in the world revit.. I have created a pattern of soil by means of a topographic surface important a file of the txt points; now it is defining the material as soil, that by category, in the process of making obtain always a beige material like clay render, while if drawing another surface always with the same settings is rendered correctly as lawn, moreover if in the surface created by the import I create a building platform, the vertical walls of the excavation are rendered correctly. What are they off-road?
Thank you very much
mb
Thank you very much
mb
