survey province treviso
  • Thread starter Thread starter theredsunset
theredsunset
Hello!
As the title says, I would like to propose to the workers a small question:
do you know what is the cad and the most used fem software in the province of treviso?
I already have a discreet experience with the pro-e but I wanted an opinion on what would be more useful to me to learn .
It seems to me that the question is very difficult. How do you do a census?
you should ask mother houses!
I can say that for the experience that I had during the interview that the two that I found most often are solidworks and inventor, one time I talked about catia and only one nx, but statistically it is irrelevant. . .
Among other things my experience is not in the treviso zone but in the bergamo zone, my intervention wanted to show the difficulty to answer the question, we can give you very limited opinions and to make in this case any estimate is very difficult if not with the data of the houses to the hand (as already mentioned above).
I think, however, that in the background knowing a few sw is enough, much you learn at the workplace (imho).
I am trevisod, and companies have seen enough... azzardare a "classification" is very challenging, but from what I have seen around there is autocad that does it as a master, also because many in passing from 2d to 3d han chosen inventor (or amd, so much born always there), while between the 3d I think the most widespread is solidworks, solidedge to wheel, less frequent all others.
like fem, it's even harder, I know there's everything, from nastran to cosmos etc...
question x theredsunset: where does this request come from?
companies with catia v5... did you find anything?
I'm also trevisod. the company chooses its own cad depending on what it has to do and what it is willing to spend. Therefore, in small companies often find autocad and inventor, especially in the wood and small carpentry sector where you do not need a powerful cad. in the processing of sheet metal (especially in the so-called stainless valley, that is that band of territory that goes from victorious veneto to oderzo passing by conegliano) I think goes for the maggiare solid edge. in medium-sized companies dedicated to mechanical design (prints, automations, machines or third-party processing) you can find very often solid works. Catia is located in some mediums and large companies that produce consumer products, where there is a strong design component, such as in the electrical and automotive sectors.
In fact, the company chooses its own cad also according to another factor: the presence on the territory of dealers. treviso I believe that the most impressive presence of retailers is solid works and solid edge.
beyond all these considerations, and to answer your question with which you ask what is most useful to learn, I would advise you to question what is the type of sector in which you would like to try as a designer. When you get the answer you will know exactly what the cad is to bet on.
Good job.
