suspension of a joint with equations
  • Thread starter Thread starter Mattia1680
Mattia1680
good morning to all, it is possible to stay one together inside another together with the equations, then to export everything in order to manage it externally from sw?
es: I have a saloon door that can be from 2\3\4 doors according to its size with dx or sx opening. I have to create a parametric managed externally by sw to fill in so that automatically sw update my design. I thought I'd use the equation.
and what does a subaxis have to do with suspending?
managed externally by who or by what?
we start from the beginning:
You've got an axe inside a sub-axeme.
what do equations manage? first-level axieme data or second-level axieme data or both?
How do you manage equations? with data table? another way?
What does it mean to externally manage a subaxieme?
What do you mean to export?
and finally what is your comoscence of solidworks
1) I have a set with various sub-axioms inside.
2) equations manage both data.
3) I do not use data tables
2) for externally managed I mean a txt file created by exporting it from equations.
I continue not to understand the request to suspend a subaxis and what does this have to do with the export of everything (all what? )
My initial question was simple pier, maybe read it.
Anyway let it go I solved and before worrying about altrue knowledge think for his.
well this is the spirit of a forum, to put to the sedan who tries to understand the problems of the applicant, because if I ask questions it is not to make me your own facts, but because to me personally the request is not clear and I try to deepen it, and in fact I have specified it in the last post; if I ask what skills are not to give you of the ignorant, but to understand what is the degree of knowledge of a software as many users of the forum make requests having little more than the basics.
the spirit of a forum is above all to make a request, to find independently the solution and non share it because everyone has to survive for their own things.
the question is formulated in a simple way, no doubt. we read
it is possible to suspend one together inside another together with equations
Of course, the fact that you ask him from additive to the fact that the knowledge of the software is low
then export everything to manage it externally by sw
Yes or no, it depends on what you mean to export everything
